Curtain wall display options...
Achille Pavlidis
When placing a curtain wall with a door, there is the possibility to have the door appear as symbolic and scale sensitive, (although with no marker...)
but there isn't the same possibility with the accessories.
I have a curtain wall with sunshading, and the only way to have the sunshader appear in the floor plan, is to set the Floor Plan Display to "Projected with overhead", but then the doors will not be symbolic anymore thus no swing line.
Plus i have to remember to change the opening angle in 3d to 0 degrees when doing the elevations.
Is there any workaround?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
0 REPLIES 0
