Curtain wall problem
When I draw a curtain wall I accept the points then it moves away, When I select created courtain wall a line construction exists from points to courtain wall, what is this about?
Thanks for help!
NCornia
Graphisoft Alumni
Graphisoft Alumni
There is an option in the Curtain Wall settings to offset the reference line. Adjust the values to get the desired placement. See below.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
