‎2013-10-16
08:59 AM
‎2023-05-24
09:08 AM
Rubia Torres
‎2013-10-16 01:47 PM
‎2013-10-17 02:41 AM
laszlonagy wrote:Do you mean edit Grid Lines (aka Scheme) manually? I set vertical Grid consistency to 20 mm that gave a decent result of the corner (however I also got other tones of Mullions on the other side of the wall).
No, there is no such setting.
When I faced this situation what I did is I placed several new vertical Grid Lines into the rightmost panel to be able to approximate the curve. It will create Frames along those grid lines but you can easily delete those frames.
‎2013-10-17 05:07 PM
