2021-11-16
11:56 AM
2022-09-22
07:06 PM
Oleksandra Vakariuk
I searched for a similar thread, but I didn't find any.
I'm trying to create curtain wall façade, which has many different panel sizes and openings, however I can't "turn" the scheme pattern, at the corner, the pattern starts from the beginning and I can't create symmetrical corner openings for terraces.
I don't like the idea to create two single curtain walls and try to connect them at the corner with custom corner frame. It doesn't work properly.
Does anybody have an idea?
Thanks in advance!
2021-11-17 01:59 PM
Hello Terzer,
Can you illustrate your goal ?
2021-11-17 04:26 PM - edited 2021-11-17 04:28 PM
Hello Christophe,
What I would like to achieve is shown on the following screenshots.
This is the scheme in the order it is supposed to appear, it doesn't matter the pattern origin:
I want to achieve this pattern:
But the result is this:
The pattern always starts from the beginning at the corner, so I can't create curtain wall with unique pattern at the different sides.
As I said I don't like the custom editing of the curtain wall, I don't think it's reliable for big projects.
Cheers!
2021-11-17 05:19 PM
Thank you for the clarification. It is indeed much easier to understand that way. At the moment I am performing the same analysis as you and I am unable to get the result you want. I am nevertheless continuing my investigations.
