terzer
Curtain wall scheme corner pattern origin
Hello,
I searched for a similar thread, but I didn't find any.
I'm trying to create curtain wall façade, which has many different panel sizes and openings, however I can't "turn" the scheme pattern, at the corner, the pattern starts from the beginning and I can't create symmetrical corner openings for terraces.
I don't like the idea to create two single curtain walls and try to connect them at the corner with custom corner frame. It doesn't work properly.
Thanks in advance!
3 Replies 3
Hello Terzer,
Can you illustrate your goal ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
terzer
Hello Christophe,
What I would like to achieve is shown on the following screenshots.
This is the scheme in the order it is supposed to appear, it doesn't matter the pattern origin:
I want to achieve this pattern:
But the result is this:
The pattern always starts from the beginning at the corner, so I can't create curtain wall with unique pattern at the different sides.
As I said I don't like the custom editing of the curtain wall, I don't think it's reliable for big projects.
Cheers!
Thank you for the clarification. It is indeed much easier to understand that way. At the moment I am performing the same analysis as you and I am unable to get the result you want. I am nevertheless continuing my investigations.
Christophe - FRANCE
Archicad 15 to 29
