Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Curtain wall
I am trying to create a curtain wall which is a roof of a large scale building. By default it's very detailed. Could I simplify it? (It doesn't matter how many panels it has, it could be made out of one as I am using custom panels on it later.) Thank you.
4 REPLIES 4
Please, please, please, how can I change this curtain wall
to as simple one as this
Ok, I have found the way to do it now )
I guess you found out that you can make all Frames invisible. That would be a way to achieve that.
But if you wanted to achieve that simple transparent shape, you could have used other tools like the Shell Tool for example.
Thank you!
