COMPOSITE INTERSECTION PRIORITIES
davor_r
Can anybody give me advice how to set up priorities for concrete and mortar in examples i captured.
In "capture" I set concrete to 900 priority, and mortar is lower. I don't like this solution because mortar doesn't fit all around wall structures. Concrete is over mortar at some edges.
In "capture2" I set concrete to 900 priority, and mortar is higher. In this case mortar cuts concrete and thats not good to.
Is there any rule how to set up material priorities?
Thanks
AC22 • iMac 3,4GHz Intel Core I5 | 16 gb ram • OSX10.14.4
6 REPLIES 6
davor_r
davor_r
atachment
Eduardo Rolon
After a quick try way I have gotten that condition clean is to use the wall end tool, the step as are:
1. Extend the wall that need the paster
2. Apply the Wall End
3. Move the wall and snap to the inside of the plaster on the other wall.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Step 2
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
The somewhat ugly result.
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
What did you use on this case for the return?
AC29 US/INT -> AC08
another Moderator
