Curved Billboard?
I intend to cover the facade of my structure with vines. This facade is curved. Finding or creating a 3d model is very difficult at this point therefore i opted to use a vine png. With this png I intend to use the billboards feature to place them into archicad. Is it possible to curve the billboards to achieve the desired look. Any alternative would be welcomed. Thanks.
6 REPLIES 6
Erwin Edel
Use a curved wall, object or morph and set it up with a new surface material with the texture applied to it. Allign the texture so it fits nicely.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks
The standard Archicad Hedge object has a "bended" setting (I think that means "curved"). This would create lots of polygons though.
...And the Hedge #1591 object from Cadimage's objects (not sure if its free to download or for Select members only) can be curved in plan AND along its length vertically.
Thanks @s2art. If I'd like to have a vine with flowers all id have to do is change the hedge's surface to one with flowers?
Both of these hedge objects are made up of individual leaves. If you made the leaf diameter quite large and used a surface material with a leafy image with flowers, and transparency where there is no leaf, you could get good results with not too many polygons
