Curved Curtain Wall
Im trying to create a curved curtain wall in a curved wall but when i go to Window Selection Settings and try to get a curved curtain wall i just dont see it, I only have the W Curtain Wall Strait, does anybody knows what can i do?
Edgar.
4 REPLIES 4
Edgar,
Check in classic windows for a curved metal window.
Peter Devlin
Thanks Peter, that could also work but im actually looking for this curtain wall, (check pic)
__archiben
mate
that curtain walling can only be used as an object rather than a window element. it means you need to place an emtpy hole in your wall first. it's a bit of an inconsistency.
also. that particular curtain walling will give you curved glass as well. whilst this is possible, in reality it's so expensive that is almost never done. i tried once to re-script it for straight/faceted glass, but my GDL knowledge wasn't (and still isn't!) up to it.
HTH
~/archiben
b e n _ f r o s t
Thanks archiben, i found it just like you said it was in the object tool instead of the window tool, thanks so much take care
