working with libraries from 7, 8 and 9
Excuse my ignorance if this topic has been dealt with before (I'm sure it has, just can't find it).
Is there an easy way to work in 9 on a project that contains library parts from 7 & 8 without loading those libraries? Seems that I have read a post somewhere, but can't find it.
I am trying to place houses on a site plan done in 9. Some houses were done in 7, some in 8. Do I have to load the appropriate version of the libraries to get the houses to render properly, or is there a way to do global substitution?
The project load time is exhausting when all three libraries are loaded.
Thanks
Rip Weaver
Town Landscape Architect
The Town of Mt Laurel
Mac OSX Cube 500 mHz
Archicad 8.1/9.0
Aaron Bourgoin
Rip,
try loading those libraries and making an archive file of the building. You can then extract the library of this file - it will be pared down to only the parts you're using. That should load faster.
The one caveat will be Macros called from the older parts. If they don't show up, you'll have to add the macros to your library manually.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
