Curved Roof & Gutter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-04-16
02:27 AM
- last edited on
2025-01-02
03:39 PM
by
Molinda Prey
Hi Archicad Community,
I'm working on a CAD model of an existing building that has a lot of curves in the walls, and warped roofs. As the project will involve extending the building with more of the same, I need to create the building as it exists today. The issue I'm having is creating accurate guttering:
I've created a complex profile and can easily draw the gutter in. Using the magic wand tool, I can then create curved guttering. The issue then becomes incorporating the fall into the gutter. Once the gutter is curved, it can't be rotated on a vertical plane. I've then converted the curved beam to a morph which allows the rotation (this is clunky at best). This works to a limited extent. I can get fall, but it doesn't match the curve of the roof well. Also, once converted to a morph, the intersecting joins disappear.
I tried my luck using the magic wand in the 3D window (thinking it may clip to the roof edge): this gives me the curve but again leaves the vertical aspect out.
Does anyone know of a work-around? Does anyone have any suggestions?
Thanks in advance!
- Labels:
Complex Profiles
Roofs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-04-16 10:29 AM - edited 2023-04-16 11:35 AM
2 solutions:
Apply Your profile to a rail without anything than the profile - rails ran follwow hight-adjustments.
or
simply draw a profile as Morph and "morph-SEO-add it" to a 3D-Morph-line-path and follow it.
