L-Sacco
columns and beams end cuts Acad 18
Good morning,
I would like to know whether in the archicad 18 environment there is a possibility to create an inclined beam or column profile that starts with a cut perpendicular to the plane and ends with a cut parallel to the plane (the reinforcement of a column-pillar node for example).
Or whether it is possible to rotate a beam on the axis perpendicular to the axis of lay-up: obtaining an inclined beam, but without changing the angle of the end cuts.
Thanks in advance to anyone who can help me!
0 Replies 0
