2026-04-09 12:57 PM
My beam height are different. so, I need to adjust my column height according to my beam. What is the easies way?
2026-04-09 02:53 PM
Probably going into 3D and displaying only the relevant Columns and Beams. You can probably select multiple Columns, then change their height in a single step, either by typing the new height in the Info Box, or by adjusting their height graphically using the Pet Palette. If you have several Columns selected and you adjust the height of one of them graphically, all of them will be adjusted.
