Curved SPLINE walls?
Is it possible to convert a spline into a wall?
I have organic splines in plan view which I need to convert into walls. Is it possible in ArchiCAD? I don't want to go tracing it manually with arc/circle wall tool, since I don't want to destroy the light organic feel in the spline contour.
Thank you in advance!
(I've good AutoCAD knowledge, just switched to ArchiCAD 9 EDU - I like it!)
10 Replies 10
__archiben
Vytis wrote:
This would be perfect, and I believe it's possible, but in any way, is just a minor inconvenience.
now that you have your bottom section of walls faceted to 2000mm lengths, you can add 2000mm windows without having the annoying error messages. you can then use the window tool settings to display the glass/joints as you wish....
HTH and makes sense.
~/archiben
b e n _ f r o s t
