Curved wall
For a project on school I'm trying to make a builiding with archicad
It's almost ending now but I've got one problem.
How can I make a curved wall on the first floor (see imagine)
The point is, that the roof is not defined as roof. It's designd with
design -> Trussmaker. The wide of the truss is then the wide of the building.
That makes it, that I cannot use the option trim to roof
It there any possibility to covert my truss(roof) to a roof or to make with an other option those curved walls?
Thanks so far...
The Running man
15 Replies 15
With profile-manager you can provide wall and column.
You can do put door and window.
sorry for the late reaction but I have been very busy with school.
Thanks for the many reaction and I will give it a try using SEO
By the way, I use archicad 10 and to Peter Devlin, my roof already extends of 2 part, 1 main roof and 1 section that curved to underneath the floor
I'll get back to you but thanks so far
The Running man
The wall is there with using Complex Profiles. It makes a nice curve and there are no open area's between the roof and the wall.
Using CEO didn't work with me, because the roof could not been seen as a target element.
But my next problem is that I could not put a window in it.
Archi User 77 wrote that it is possible to put a window in it but does anybody know how?
Greets, The Running man
when you create a profile, you can then place a wall on the plan, select it and then, from the profile manager choose, apply to selection. You should then be able to place a window or door..
so I have to place the window in the profile manger and finish it with the wall and than place the wall included the window in the plan?
Djordje
man,
OS and Archicad version in the signature, please.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
