Curved walls 3D intersections disappearing
znj
My walls look correct in 2D and even in 3D their base is visible, but the model is breaking on each segment. What could be the problem?
Gerry Leonor
see if there's anything that's hiding the top of the walls in a hidden layer. perhaps there's a beam or slab that's acting on them?
try a different 3D view. if you switch from Wireframe, to solid lines, to solid shaded views, do the tops still disappear?
https://discord.gg/XGHjyvutt8
Thanks, but neither of the suggestions help the problem. Seems more of a glitch, I am working in AC26 and noticed several bugs already.
Guru
How thin is your wall, and what radius are your curves? AC segements curved enterties for 3D representation, which might be causing self intersections, and hence the failed geometry generation.
Ling.
