‎2010-05-30
04:00 AM
‎2023-05-25
05:33 PM
Rubia Torres
‎2010-05-30 07:25 AM
‎2010-05-30 06:13 PM
allegronea wrote:You can use OBJECTiVE to do the following (refer to the attached image):
I'm trying to curve a stair so it will be flush with a wall, but I'm having trouble figuring out how you can change the bend of the stair.
I've seen a few forums on this using the OBJECTIVE tool, but I really haven't found anything actually describing the motions of how to do it.
‎2010-05-30 06:31 PM
allegronea wrote:You can similarly add a handrail. Referring to the attached image:
‎2010-05-30 10:55 PM
‎2010-05-30 11:00 PM
lec1212 wrote:It's made and manipulated with OBJECTiVE (see steps 1 & 2 of my first reply). OBJECTiVE can cut or rotate a StairMaker object, but not bend it.
Is the stair you show made and manipulated in Objective or is Objective being used to modify an Archicad stair?
‎2010-05-30 11:22 PM
‎2010-05-31 02:22 AM
lec1212 wrote:Lec, You know that you can change the settings for the (2*Riser) + Run > or < windows to different values to get rid of that pesky kiss of death right?
Thanks Ralph.
Doesn't look like it will give me the kiss of death like Archicad stair tool does
lec
‎2010-05-31 02:57 AM
‎2010-05-31 06:08 PM
