Custom Railing Pickets...hubboy
rob2218
see attached.
besides making EVERY LITTLE bit and piece of this railing a part of objects...how best to accomplish (see red question).
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
9 REPLIES 9
rob2218
I can't believe I'm going to have to make this "handrail" design as parts and pieces with little pickets and horizontals cause there is no "custom" handrail.
geeez.....
i>u
Edgewater, FL!
SOFTWARE VERSION:
alemanda
Truss maker is the solution.
Just draw it in 2d (elevation) and transform it with truss maker.
It's easy.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
rob2218
hubeda....hubeda...HUWhat?
please...ellaborate on your steps.
It's easy.
i>u
Edgewater, FL!
SOFTWARE VERSION:
alemanda
This is an explainig video.
https://www.youtube.com/watch?v=-GA4Ye2rgK0
The only limitation is that it is not adjustable on the fly.
Enjoy!
AC27 latest hotfix
Win 10 Pro 64bit
rob2218
So...I'm familiar with "Truss Maker"
I guess you are then taking the approach to create a "truss" for the stair railing in angle?
Thing is...that then I'd have to determine the exact "midpoints" of the vertical pickets and the horizontal members so that I when I create the "truss" to be used as a "stair railing" it'll offset the proper amount.
So, if my steel picket members are say 1/4" thick, then the linework that is used to create the truss needs to be inboard by 1/8" in order for the truss to expand outward properly?
Yeah...and the non-parametrics on the fly don't help.
i>u
Edgewater, FL!
SOFTWARE VERSION:
David Collins
Not entirely painless, but you might think about modeling it as a morph. One thing it took me a while to discover is that you can create morphs in elevation and section windows. This is really nice for things like stair railings and ramps. The 2d morph is created in the plane of the cut. Create the flat morph in a temporary section window and then extrude the depth it needs in the 3d window.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
vfrontiers
Sorry... once again I don't have time to search thru a billion posts to find what I'm looking for...This was close...
I'm trying to create a CUSTOM RAIL (Balluster or panel) in AC21. It's a repeated pattern as shown below. First I thought I'd just draw this as a PROFILE and the Balluster will display this at a regular interval... But the profiles extrude UP and not FACE ON... ugh...
So dug deeper and see that you can call up SUB COMPONENTS for RAIL PANELS... ok... I'll just create some slabbies and save as a RAIL COMPONENT... Wait... there is no RAIL COMPONENT Save as? Looking the the MANUAL... I see that your supposed to do that with MORPHS... ok.. I make them a MORPH... But once again... there is no SAVE STAIR COMPONENT option. The manual clearly shows it available but it's on a WINDOWS platform... Is this NOT available for MAC?
Then, I presume that if I just create an old style OBJECT, I can just redefine it's SUBTYPE and I'm golden... but yet again... there are several RAIL RAILING options for subtypes, but NONE make it show up for the railing tool...
Any advise welcome...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
vfrontiers
I did find the correct SUBTYPE... so had to create as a NORMAL object then convert to subtype...
Now what I'm seeing is that the FACE of the rail is set to the reference line, which puts it HALF A RAIL THK off center... Tried to just make an adjustment in the MOTIF obj... but no matter where I "MOVE" it to... it always thinks the FACE is 0...
I know this is alway USER ERROR for me... so be kind!
Just using the OFFSET CENTERLINE shifts the entire railing off the centerline... not just the motif
Duane
Visual Frontiers
vfrontiers
Ok... well I guess I just have to POST stuff here in order for me to learn!
I found the HORIZ. OFFSET in the railing settings...
Good for now... Lots more to learn
Duane
Visual Frontiers
