Custom Wall,Door and Window Placement
I am having problem to put door and windows in custom made wall. I made a custom wall and put it as an new object. But now I cant put any door or windows in it?? Wall Consists of Brick,airspace,insulation, and concrete.
Thanks
1 Solution
David Maudlin
Mahesh:
The video shows how to make an Object (Chair icon on ToolBox) not a Wall (Wall icon in ToolBox), Objects do not host doors and windows, only Walls do. In AC 16 you can create a Composite Structure to use as a Wall (in the Help files see Configuration > Attributes > Composite Structures > Define a Custom Composite Structure), which will display the various skins in plan and section, but not 3D. AC17 has introduced a new attribute (Building Materials) that will display the wall composition in 2D, Section and 3D.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
3 Replies 3
David Maudlin
maheshkarki123:
If the wall is actually an Object element, then it will not accept doors or windows, only Wall elements can host doors and windows. Post a detailed explanation of how you created the object, and a screen shot of its appearance, and someone should be able to suggest a better work flow.
David
I am a beginner at arhicad and I am trying to learn it by looking at different videos and checking on different forums. I made a wall object by looking at this video.( https://www.youtube.com/watch?v=4-Q0SQX21wQ)
But when i try to put a door in wall, i was not able to do it.
Mahesh Karki
Student
Archicad 16, Intel Core i7-3623QM @2.20ghZ, RAM 8GB,Win 8
David Maudlin
Mahesh:
David
