I'm also curious about the Cadimage Accessory Pack.
We use WallSurfacer from ObjectsOnline to assign different materials to a wall. It is an easy and cheap solution ($40) for picture 2 detail B.
Because it can cut in walls under an angle we also use it to model gutters. Just draw some wide short walls and cut out the profile, very easy and flexible.
There are some limitations however: doesn't work with curved walls and only horizontal bands of materials.
Anyone with experience with Revealmaker or other tools?
