Custom fills with hotspots
Hello hello
Regarding simple 2D custom fills.. manual says: is possible to create them using lines, arcs and hotspots.
I assumed that hotspots will give you the possibility to snap in the points of the fill where have been located while creating the pattern, however it doesn't seem to be the work. Was I dreaming too much and hotspots are only tools to help drawing your pattern?
Is there any way you could snap in a point inside the fill?
Hope I made myself clear.
Cheers in advance for any help
you cannot snap to elements within a hatch, a hotspot in the hatch definition creates a dot in the pattern
Thanks mate
Have a good weekend
