SOLVED!
Custom opening in a Curtain Wall
Arabrab
Hello,
How to create custom openings in the Curtain Wall for doors and windows?
In a model provided in one of the Graphisoft's learning lessons, I noticed this Curtain Wall object that has holes carved into it for the doors and windows and I can't figure out how they made it.
I know how to make a hole in the curtain wall by using morphs, but when analysing this model, this doesn't seem to be the method they used.
Also, removing panels in Edit mode doesn't lead to the desired result...
If someone could reveal this magic to me, I would be really grateful
2 ACCEPTED SOLUTIONS
Solution
Ricardo Lopez
Hi @Arabrab
The outline boundary of the Scheme Grid did the trick.
You can get it by editing the curtain wall and turning off everything but that. Then select that thicker line, it will turn in blue to edit.
One condition: it has to be a continuous polyline.
Regards. -
M. Arch. Ricardo López
Solution
Can't you just place extra frames around your openings and then delete what is inside (the frames can be invisible).
4 REPLIES 4
Solution
Ricardo Lopez
Hi @Arabrab
Regards. -
@Ricardo Lopez thank you for the support, this did the trick!
Tam-taaam 👇👇👇👇👇👇
Cheers!
Solution
Thank you @Barry Kelly for enlightening me!
Et voilà! 👇
Screenshot 2024-05-25 084621.pngScreenshot 2024-05-25 084811.pngScreenshot 2024-05-25 084850.png
In Graphisoft's exercise file where I discovered this particular Curtain Wall object with the window holes, they used the method that @Ricardo Lopez explained.
Thank you both @Ricardo Lopez and @Barry Kelly
/ barbara
Setup info provided by author
