JelenaKujundzic
Composite roof and wall not cutting properly - why?
Hi, why does archicad cut out differently wall composite with slab and roof composite?
I want my wall composite contact with the roof to be cut out the same way the slab is.
I want brick to go up to the second insulation line, and the plaster to be cut out at the first layer of insulation (as with slab).
Operating system used: Windows 20
I suspect this may have something to do with which command you used to create the Wall-Roof connection. Please watch this clip, it may contain the answer you are looking for:
https://www.youtube.com/watch?v=K7OZ_fU7eGA
