Custom staircase
I am trying to make a curved staircase and ramp with customized curves - somewhat wavy. i managed the ramp with segments of the ramp object with varying radii. However, I am unable to figure out the staircase!
Any ideas?
Thanks
If I understand correctly the simplest approach is probably to use slabs with SEOs to subtract from the ramps to form the steps.
A picture would help.
Are you trying to use the built-in StairMaker?
If so, you're just wasting your life.
