‎2024-09-28 01:39 PM
Hi!
I'm modelling an existing building, but I'm struggling with this window in particular.
I've tried so many different window types and settings, but I can't get there.
Does anyone know how to model this window?
I've added a picture of the existing window and how far I got.
Thanks in advance!
Kind greetings,
Demi
Solved! Go to Solution.
‎2024-09-28 04:07 PM
Probably not possible with a single window.
But you could try ganging a few windows together.
Or a Guillermo1 suggested, try the curtain wall.
Or create a custom window from slabs, it is quite easy (search the help file).
Or use library Part Maker to create one, that will give you more control of the 2D symbol.
‎2024-09-28 03:17 PM
i think that it can be modeled with curtain wall tool
‎2024-09-28 04:09 PM
ah thanks! I think ganging up windows is the easiest and quickest solution for now 🙂
‎2024-09-30 03:17 AM
The downside of Ganging is Scheduling, if required...
