Cut Surfaces/Floor Plan Display
Hi there!
I did a project 4 years ago but now I don't like the colors/cut fills I chose.
All the walls have different thicknesses and elevations. So I changed the definitions of the cut surfaces on one wall. But then, if I choose to inject the parameters to other walls it changes the thickness and the elevation according to the first wall.
Is there a way to apply the same floor plan and section display (like the cut surface definition) to other elements? Without changing the thickness or the elevation?
Thank you!
No means for copying / injecting. Instead, you have to select all walls that you want to change (Edit > Find & Select can help here) - and then open the Settings dialog. The changes you make will affect all selected walls. So, if all you change is the material, all that will be changed in all of those walls will be the material - thickness, height, etc will remain.
Thank you! That helped me a lot!
