‎2012-11-05
09:47 PM
‎2023-05-23
04:34 PM
Rubia Torres
‎2012-11-05 11:29 PM
‎2012-11-06 04:10 PM
‎2012-11-06 05:33 PM
laszlonagy wrote:Well, features have warnings, bugs just happen. I've been talking with GS Tech. They've reproduced the problem so are now aware of it.
Probably at the least there should be a warning telling you what is about to happen so you are aware and dont have to find out later.
‎2012-11-06 05:55 PM
uisanata wrote:Thanks uisanata, but I wasn't looking for anyone's advice regarding unlinking elevations. There are reasons--and benefits--to unlinking in some cases. Hence the feature. The fact is that the label function does not work correctly in this case.
Your assumption is correct and I think the labels function correctly. What you really want is an extra-feature of the elevation, to be able to keep this information after the section is converted, which would be nice, but wrong. Elevations are supposed to be connected with the plans, not just simple 2D drawings. If your elevations are not looking OK and need more work, it's probably a default model. Just my 2 cents...
