Stretching morph along Z?
Is it possible to stretch parts of a morph in Z-dir? (without pull/push) I've tried some different ways but none of them will work.
4 Replies 4
Stig Bengtsson
Yes, with the bounding box stretch method.
Stig
Architect AIA RIBA SAR/MSA, Graphisoft Registered Consultant
AC19 SWE 7006
AC20 SWE 4012
True, but, it should be possible to define it's geometry before stretching (stretching the bounding box before stretching the morph).
Now I got alot of morphs that have a couple of points in the middle that should be stretch downwards, if I mark all that polygons with normal marque, I also got alot of unwanted polygons marked, so my bounding box are much bigger than I want it to be. And unmark all this polygons is a nightmare, give us an MARK and UNMARK option. Now we only have the option "change status between marked and unmarked", there isn't any option "SET status mark / unmark" (Or is it? )
Could you show an image of the exact situation you are facing?
I will post next time I got this problem!
