ā2007-11-12 05:55 PM
ā2007-11-15 08:39 PM
Thomas wrote:I don't know how good I am with communicating my question and thoughts through here with typing.
Well, i'm not sure I understand you completely...
The Help files are really helpful!
You have a number of pre-defined Pen Sets in the program. There's a list at Options>Element Attributes > Pens & Colors.
If one of them suits you, fine, otherwise customise and save one of your own. You can use any color and pen width for any pen. I usually use an Autocad standard pen set of my own because it makes conversions easier.
Now open your layout, select the view in question and right-click. Select Drawing Selection Settings. In the dialog, open the Properties tab. There in the lower left, select the pre-defined pen set you want. Then, on the right, you can override it with greyscale or everything black if you like. Click OK.
If the DWG refuses to display the way you want it after the above excersise, you can workarund it by importing the DWG into a separate .pln document and then Hot-link that into your current project. This will give youeven more control.
If none of this works, I don't know.
ā2007-11-15 09:14 PM
ā2007-11-15 09:39 PM
Ben wrote:Maybe I can do some print screens and show you guys what I am talking about. I am going to try to explain it one more time. (I think its a bug too, maybe)
Jess,
Change your pen set again. This time redefine your view, the one that is placed on the layout. Do an update, you should be seeing the DWG pen set now.
Mmm For get about what I wrote above. I think you may have found a bug? It's not working as it should. I did a redefine but it didn't work. This is a work around though. If you mark the view on the layout, then bring up the drawing selection setting dialog, you can change your pen set in there to the one you want.
Cheers.
Ben
ā2007-11-15 09:46 PM
Jesikuh123 wrote:yes. i thought if this is a bug with viewing DWG drawings you've found, if you import it into an empty Archicad project, and then hotlink that, it's no longer a DWG, thus you would avoid seeing the bug...
Are you saying that I should open an empty Archicad project-Import the DWG file, and save it out as a hotlinked module with the pens I want to be displayed on?
ā2007-11-15 09:51 PM
Jesikuh123 wrote:Of course. To make translations consistent, I tend to use the Keep Pen Index Number translator and assign a pen set to the import that gives me the look I want. Check the Help files!
Now- Isnt there a way we can assign a translator of some sorts to DWGs that we bring in? and how?
ā2007-11-15 09:52 PM
ā2007-11-22 06:22 AM
