ayman wrote:
so,wich the best way to draw building like this?
currently . . . use of very basic walls, slabs and roofs combined with copious SEO'ing. ensure that all elements have the same sectional/construction fill and they'll clean up in section allowing you to generate useful
clean sections from any point in the model.
once you've done this and understood the basic, single-skin, junctions you can start applying cladding with the use of accessory tools . . . or even convert some of the elements to composite structures.
you will need to look carefully at the skylight objects to see what you can achieve with them - you may even have to write your own skylight objects that resemble the kind of doors and windows you may or may not need in your sloped walls . . .
anything's possible, but if that doesn't work for you, there's always
catia.
HTH
~/archiben
b e n f r o s t
