Default Story Height To Next
Is there a way to change the default value for the Height to next story in the Story Settings dialog? Australian default set to 2900mm which is really only suitable for carparks.
Scott Boyd-Turner
HP Z400, Xeon W3520 6 GB RAM, NVidia QuadroFX1800, 22" (1920x1080)
Win7-64 Professional ENG
AC 15 AUS 3267
You can influence it if you change the default settings of your slab tool and wall tool.
The "Height to Next" is actually your default slab thickness added to your default wall height.
So if you change either or both of those to add together to be the height you want then all will be fine.
Trouble is it is just as quick to add a floor an adjust the height as it is to check the defaults and adjust those just so you get the right floor levels.
You should create a Template file.
Set the values to your preferences and save it as a Template file.
