‎2007-02-27
03:52 PM
‎2023-05-23
05:10 PM
Rubia Torres
‎2007-02-27 04:16 PM
‎2007-02-27 04:35 PM
‎2007-02-27 05:11 PM
Jesikuh123 wrote:Right. You would have to re-do all your work.
These are library parts that are from the Archi CAD Library- yes.
If I save them into my own company Library with the default settings I want , what do I do about updating the Archi CAD libraries, when updates are available? I won't be able to update my parts that I changed the pens for right?
‎2007-03-01 01:20 AM
TomWaltz wrote:Hence the advantage of favorites. I use pen 1 for all of my plan and section cutlines for most objects (except plumbing = 4). I thought there was a tool in the developer kit for doing this kind of global overwrite to common parameters. Is this correct?
‎2007-03-01 01:49 AM
andyro wrote:it was promised back in the 10 beta when GS made a pigs' breakfast of the pens sets and legacy penset compatibility . . . it never arrived . . .
‎2007-03-01 02:09 AM
~/archiben wrote:Still? (agape) WTF! I need it!!!!
‎2007-03-01 03:28 PM
‎2007-03-01 09:46 PM
Mike wrote:Well, kind of.....
...In addition it is not as painful to update the favorites for library parts between versions by loading both old and new libraries and using the parameter transfer in the library dialogue box.
‎2007-03-02 02:32 PM
Jay wrote:I was able to convert my 9 favorites to 10 objects relatively easily, but I don't use standard windows and doors which might be more problematic. The other big area of change was between the detailer objects that seemed to get a major re-work. I only loaded both libraries for the time that I transfered parameters from my 9 favorite to the equivalent 10 part and re-deffined the associated favorites.
Well, kind of.....
The AC9 Standard Library does not "marry" well with the AC10. The AC9 SE Library was explained to me as being the library in AC9 that would translate over to AC10. Alas, the AC9 SE was very buggy, and when AC10 library (which was really a Fixed AC9 SE library) was released, they did not go back and fix the bugs in the AC9 SE library. So for me, I did not develope my favorites based on the AC9 SE library, and therefore for at least the trip from AC9 to AC10 will not be as simple in regards to Favorites.
