I've had problems with these type of complex profiles before.
Most commons causes:
- holes in the profile; solution: fill them with 'air' building material fills
- unnecessary nodes on fills (what should be one straight segment is made up of several segments); solution: get rid of them, check the fills that touch eachother for this
It is very important to draft neatly and precise for these kind of profiles. Fills not touching or segments at a 89.99 degree angle can cause problems.
I've had colleagues who would just copy and paste product detail DWG drawings and take it from there. These files are typically riddled with faulty linework and unprecise measurements. Definitely not something you want to extrude along long walls in your model.
Even if the profile does not give warnings, if there are any of these problems, you can be setting yourself up for long rebuild times in floor plan view, though this might be fixed since we last had these problems (around ArchiCAD 14).
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
