SOLVED!
Deleting elements
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-02-20 12:06 PM
2020-02-20
12:06 PM
Solved! Go to Solution.
1 ACCEPTED SOLUTION
Solution
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-02-20 12:25 PM
2020-02-20
12:25 PM
Hello chris zang,
Your printscreen is a great idea. Thanks about it !
I see grey points around your selection, that means your elements are locked.
1° - Check if layers are unlock
2° - Check if these elements are not locked - Clic on : Edition/Lock/Unlock
3° - If you are working on a teamworks project, you have to reserve elements before editing them
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
3 REPLIES 3
Solution
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-02-20 12:25 PM
2020-02-20
12:25 PM
Hello chris zang,
Christophe - FRANCE
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-02-20 12:41 PM
2020-02-20
12:41 PM
Hello Christophe,
Thank you for your feedback, it was indeed locked i managed to unlock the layer and was able to delete the parts selected. Now trying to export the updated file as ifc format. I had bad success with Revit when trying to export the file the app was not responding during the export i contacted the support they said the file is too big but archicad just managed to export it
Thank you again.
Thank you again.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-02-20 12:52 PM
2020-02-20
12:52 PM
Chris zang,
If you see dots instead of element into you model, check your library links.
Archicad is the easiest way to export a good ifc file😉 but before doing it you have to check your classification and IFC translator.
Christophe - FRANCE
