poco2013
Mentor
Design Option Copy/Paste
Does anyone know the procedure to copy paste a object from one plan into another, where the object was previously create in a option set. if I try to copy/paste a option object, I get the message:
Elements have been created in currently inactive design options.
As a result,these elements will be hidden until their design option are activated.
it does matter if I have the identical design option set up in the second plan, they still disappear no mater what option I click on. If a object was created on the main model -- no problem. Maybe you can't do this? Hotlinks seem to work OK, but there, you have to use the hotlink dialog to control the options of the placed hotlink?
Gerry
1 Reply 1
DGod
Trying to find out the simplest process as well.  Shouldn't be that hard. Currently I'm using the copy/paste/ undo / Transfer Link method.
Seams like an pop up option to paste to current design option or paste to original would speed things up a great deal.
