Detail Boundaries not showing up in Plotmaker
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-04-14
12:44 AM
2023-05-26
03:15 PM
Rubia Torres
2005-04-14
12:44 AM
I've looked for some setting or Display Option, but can't find any that will make it appear.
Any ideas?(he said, hoping it wasn't something simple that would again make him feel stupid...)
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-14 01:47 PM
2005-04-14
01:47 PM
Jeff:
Have you looked at Options>Display Options... Detail Boundary: Show or Hide? The display options are one of the settings of the Viewset, so they need to be set up correctly when defining (or redefining) the viewset. These settings then determine what shows up (or not) in PlotMaker.
Hope this helps.
Hope this helps.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-14 05:55 PM
2005-04-14
05:55 PM
I double-checked the Display Options in AC for that section and it has the Detail Boundaries box set to "show." (Isn't that setting just for display, though? Those top settings don't affect the output to Plotmaker, do they?)
Thanks for the input.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-14 06:39 PM
2005-04-14
06:39 PM
can you post a screenshot? as I recall, the detail boundary (which I don't think can plot anyway) only shows up on the 1st box drawn to establish a detail. perhaps you are working with copies of the detail, or linking to an existing detail when you draw your marker?
hth
wes
hth
wes
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-15 03:01 PM
2005-04-15
03:01 PM
Jeff:
In addition to Wes's request for screen shots, some more information might help:
1. Are you missing the boundary in the plan and/or section window, or the boundary that shows up in the detail window?
2. If in the plan and/or section window, are you missing the editable boundary that defines the size of the detail, or the graphic boundary who's appearance is defined under the General Settings parameters for the marker.
3. Which marker are you using, are all markers acting the same way?
4. In PlotMaker, are you importing directly from the archiCAD file or creating a pmk file to bring into PlotMaker?
Hope this helps.
Hope this helps.
