Empty Wall Openings Problem
I've been using empty wall openings on my project but at the moment of generating door Schedules the empty openings count as if they were a door ....the same applies to windows....
I could have use solids operations to create the opening but it would take to much time...
Does anyone out there knows how to unlink an empty opening from the door and window schedule ?????
Thank You guys!!!!
4 REPLIES 4
Stress Co_
Try this:
Name the door which you DONT want in the schedule "empty door". Then set the Schedule settings> General> Criteria ....like this:
I hope that works.
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
WOW!!! it really worked but now how can I get rid of the ID marker so it doesn't count on the ID list besides selecting the option NO MARKER on the door settings
Thank You
Stress Co_
Thank You
Oh, man .... I did this a while ago and can't remember exactly what I did-how I did it, but.......if you look at the line below "empty door" (in my earlier post) you'll see Criteria "element ID". I think I gave all the doors I didn't want in the schedule "NIS" (not in schedule) to get rid of them ....and I said "I think".
I'd love to hear if there is an easier way....?
Marc
Marc
I simply set the ID field to be blank and then have the schedule set to omit items with no ID. (I don't have a schedule to look at on this machinne, but I believe you add element ID in the schedule settings and set it to <> and then leave the field blank.)
