Detail Markers
Detail Markers? How does one get the detail marker in a circle, like the symbol next to General. When I try to use the marker all I get is numbers without the symbol.
1 REPLY 1
You have to select the type of marker you want. Under the tool settings, go to Marker and select via the pop-up menu (first thing under the "marker" heading). Valid for the Detail tool and the Section tool. Select the one you like best and you're all set.
