‎2006-02-15 08:40 AM
‎2006-02-15 10:49 AM
‎2006-02-15 11:37 PM
‎2006-02-16 04:47 AM
Caliban2 wrote:Save it as a new QuickView.
John,
Thanks for your help but do I need the Marquee tool to lift the image? If so how do I rescale and transfer it?
Thanks again.
‎2006-02-16 08:58 AM
‎2006-02-16 11:21 AM
‎2006-02-16 06:42 PM
‎2006-02-19 10:51 AM
‎2006-02-19 09:33 PM
Caliban2 wrote:Of course this works, but it loses contact with the building model. The other two methods described will keep the link. The method of creating a separate, limited section for the detail also allows you to edit the drawing without resorting to special layers or worrying about the overall section.
I think I've finally got this figured. It may not be the only way to do it but it works. Thanks for all the suggestions and advice:
1. Create a brand new project called Details.
2. Go back to the original project and do a mini section with limited parameters as suggested by Jay, and save it.
3. Use the Marquee tool and copy and paste the limited section to Details.
4. In Details you can modify as required without feedback to the original project.
Thank you one and all.
