Disable the dragbutton.
pretty much always use ctrl+d to drag, wich is why this is becoming an increasing annoyance to me.
Whenever i try edit an object (move nodes, offsets etc.), the option keeps switching back to drag for no apparent reason.
Is there any way to remove this option, or fix this "problem?"
I'm using ArchiCAD 14
Thanks in advance,
toolate.
Edit: My apologies if this ended up in the wrong forum.
Feel free to move it if it is.
3 Replies 3
I'm experiencing similar problem recently. And it is not that easy to switch to other function. There is a small delay between the pet palette to show up and when you can click on it.
This has always been a particular problem in Windows as I recall, at least in the 3D window. Much less so on the Mac.
The false clicks on the pet palette also plague both platforms but seem worse on windows as well. It's particularly annoying when a function appears to be selected but isn't requiring a second trip to the palette.
The pet palette is one of ArchiCAD's best features but I do hope they can manage to tune it up a bit.
I'm having a lot of trouble with the pet pallet too. It's really starting to get in the way of working.
