We value your input!
Disappearing cross sections and elevations
In Archicad 22, I have been having trouble with my cross section and elevation information disappearing. The icons are still visible in the plan view, but when I try to open a cross section or elevation, on any 2D information or dimensions will be visible.
If I drag a copy of the section or elevation and open that, the window appears normally with all 3D and 2D information. I then have to delete the original section or elevation and change the numbering to keep working.
2018 MacBook Pro 15 w. Mac OS 10.13.6
Ram 32GB, 1T SSD
Archicad 22
I have had similar problems. Sometimes saving and completely shutting down the machine and restarting will bring it back, but sometimes not...
Rob,
Thanks for the tip, I'll give that a try.
Perhaps my bad habit of starting a project with a "save as" and clearing out the previous project information is catching up with me ..... should be using a template, but I'm always improving things and want the latest and greatest version of my "template" going forward.
Chris
Daniel Kovacs
Sounds like a rebuilding problem. Next time you see this happen, please try doing a 'Rebuild&Regenerate' (ctrl+alt+shift+R). This might regenerate the geometry and things might appear.
Also, if you have a certain set of steps that triggers this, I would really want to try it myself to see if it is caused by a bug. Could you send me the steps to reproduce this along with a PLA version of the project? (you can send them in a private message)
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
