Disappearing stairs
For some weird reason i cant yet figure out every staircase in my plans disappears in the layouts.
I can see them fine in the project map or the view map which i place later in my layouts.
So the stairs are invisible when displaying my floor plans in layouts, but not when displaying my view maps
Just out of interest, check the renovation status of your stair.
If it looks correct, change it to something else and then change it back.
I remember reading a post that there was trouble with reno filters.
Here was the post...
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=67572&p=301250&hilit=stair+layout#p301250
8 REPLIES 8
Hello papsphilip,
There is allways a good reason 😉
Do you use archicad stairs from a previous version ? Do you do a library migration ?
I invite you to built on of them with your last archicad to check it.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
No library migration, and the stairs are native archicad 22.
When i try the same in a new file everything works just fine.
What setting could be preventing stairs from not showing in the layout? but everywhere else
Ok
Do you update your archicad or is it already a 3000 version ?
Christophe - FRANCE
I have Archicad 22 - 6021 version.
You think this could be a bug?
I had this mistake at the beginning with AC22 and no more since the first update.
Can you check and probably delete and remake your library links ?
Telling it's a bug mean we are sure there is no other reason. We can tell it cause there are so much informations we don't have to conclude as fast as you wish.
Christophe - FRANCE
thank you for replying, i will check on both solutions as soon as i can.
this worked!!!! thank you very much Barry, now stairs appear on the layouts also. case closed
