Disappearing windows
I have struggle all afternoo on AC 11 with an unsurmaountable problem.
There is probably a simple answer and I rather be embarrased asking than losing my mind.
I am unable to see windowobjects displayed in 2D, however, when I call to display the 3D window, they appear correctly placed in all respects.
I get several error messages describing problem with pen numbers in the script, I re-installed AC11, apply the latest built and nothing helps !
Any suggestions on settings I may be missing?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
3 Replies 3
Link
Can you show a screenshot? It may be as simple as your Model View Options having windows set to an alternative display option, a cut plane issue, a problem with the library not being loaded, or the part having an incorrect parameter.
Link.
Ok, I cannot replicate the problem, however, the only event out of the ordinary was to bring into the drawing, an AUTOCAD "External Reference" .dwg
In one instance, I exit AC and calledforanew drawing,using the latest settings. The windows worked but the doors, any door, produced this Warning Message -" Pen number is less than 1 or greater than 255 at line 447 in the 2D script of the file ws_wallhole_us_10.gsm"
The file is corrupted and was abandoned. I spent more time trying to figure the problem than actually starting new again.
Thanks, Lynk. T'was good to hear from you again.
Your problem may be different, but I had similar problem where window would show in 3d and not plan view, (2d).
Solution was discovering that I had inadvertently set that story height as 1 foot, which was below the "cut plain" and so window object of course would not show.
