Display of Circular Profiles in 3D
Hello everyone.
I'm using Archicad 10 (1010 update) and I want to ask for your help about the following problem: if I create a wall (or other element) using a circular profile, its display in 3D is jagged (you can see an example in the attached print screen).
Is there a way I can solve this and make the elements appear smoother?
Thank you.
0 REPLIES 0
