Display of Cover Fills on Roofs
How would I make Cover Fills for roofs display on elevations, but not on floor plans, while at the same time have the roofs displayed as Outline?
I've been trying to alter the Model View Options in View Settings, and I feel that the answer is somewhere there, but it doesn't seem to make any difference.
Where are the Model View Options defined? Is it becasue I am usinf custom Layers and Layer Combinations that is making this not work?
1 Reply 1
If the fill is associated to the material on your roof surface, leave the cover fills off the roof when placing (or editing) in plan. Check the Vectorial 3D hatching box in Section / Elevation tool settings Model Effects tab (and Distant Area if required).
Is that what you mean?
