Display options Fill controls
Hi folks,
I want to have some drafting fills show vectorial hatching, and not have my wall construction fills on.
When I go to display options, and set
Cut fills: Seperators only
Drafting fills: Vectorial Hatching
I get the seperator lines, but no drafting fills.
Is there some bizarre and burried over-ride switch that says "when cut fill are hidden, all fills are hidden"?
Thanks.
-Nathan
7 Replies 7
TomWaltz
The only thing I can think of is if some of the manual fills are not set to "Drafting Fill?" Maybe they were set to "Cut Fill" or "Cover fill" by mistake?
I have wall cut fills off with drafting fills on all the time, so it can be done.
Tom Waltz
You Rock!!!
Just out of curiosity, why would one be able to lable a drafting fill a cut or cover fill? (Actually, I realize there is probably some drawing exception somewhere that will make that really handy...)
thanks.
-Nathan
__archiben
i think you just answered your own question.
my question: how come you drew fills that were labelled cut or cover?
cheers
~/archiben
b e n _ f r o s t
TomWaltz
Nathan wrote:
You Rock!!!
thanks.
-Nathan
Probably so you could draw in manual hatches to act like walls or like slab/roof infill... maybe to clean up a plan situation or a ceiling plan?
Tom Waltz
It's easy to get your fill tool accidentally set to 'Cut', by Opt(Alt)+clicking on a fill in a drawing section or detail window.
James Murray
TomWaltz wrote:
Nathan wrote:
You Rock!!!
thanks.
-Nathan
These Fill and Line Categories are also good when saving a Section/Elevation as DWG/DXF. You might have drawn 2D Fills and Lines over your model in S/E Window, and you would probably want these fills and lines to go to the same layers than lines generated from the model will go in the resulting DWG/DXF file.
For example, if you draw a fill over a Wall/Slab intersection in S/E, the Fill should belong to the Cut Fill category because the fills generated from the section of the Wall and Slab will be in Cut Fill category.
Erika Epstein
Great tip Laszlo. Thanks
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
