Display problem with trapezoidal composite walls in section
David Collins
I've got a display issue I can't solve: I'm using a lot of trapezoidal composite walls for a very odd existing building plan (don't ask...). The walls display correctly in plan and in 3d. However in section the lines of the outer skins of some of the walls are flipped, so that the cut lines appear on the inside of the outer skin.
After some experimentation I found that this flipping depends on which side of the wall the reference line is on as it passes through the section line. A section looking the other way flips the problem to the other wall. If the reference line of the wall on the left was moved to the inside of the wall, the section shown would display correctly, but a section looking the other way would show both walls incorrectly.
Changing the direction of the wall reference doesn't affect the problem and I'm seeing the same behavior with other trapezoidal composite walls. Everything works perfectly in plan and in 3d and regular walls using the same composite display properly in section.
Any ideas?
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
5 REPLIES 5
David Maudlin
David:
I don't know the fix, but I am seeing similar behavior with all the separator pens.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Collins
Thanks for looking at this, David. At least I know its not something I'm doing wrong. Maybe the Graphisoft guys can sort it out some day.
David Collins
NCornia
Graphisoft Alumni
Graphisoft Alumni
I will make sure the developer team takes a look into this.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
David Collins
Thanks, Nicholas. Much appreciated!
David Collins
David Collins
David wrote:
I've got a display issue I can't solve.....?
Fixed in ArchiCAD 18!
Many thanks to whoever it was at Graphisoft who solved this!
David Collins
