ā2007-07-13 03:45 PM
ā2007-07-13 04:32 PM
ā2007-07-13 05:52 PM
ā2007-07-13 08:30 PM
ā2007-07-13 09:07 PM
Erika wrote:The trouble with this is that, unless they are round spindles, each one will have to be rotated tangent to the arc.
Using your the special snap, set distance to 4'. Put your local origin where you want to start your increments from and then when your cursor is on the arc, tic-marks will appear at 4' intervals measured along the arc. You will be able to place your columns at the tic marks.
ā2007-07-13 09:44 PM
Matthew wrote:Absolutely!
The best trick is to combine your method with Dwight's and Multiply by increment along the arc with Special Snap Points set by Distance to 4".
ā2007-07-14 10:12 AM
ā2007-07-14 10:14 AM
ā2007-07-14 08:30 PM
kliment wrote:Wow, that is one powerful multiplier tool. I just read the manual, and I guess the obvious question is why the hell hasn't GS incorporated that kind of thinking into the current version o f ArchiCAD? Especially now that Arexline seems to be defunct. If it wasn't, that's one Add-on I would most definitely buy today.
I keep wondering why Graphisoft does not add such a feature to the Multiply command in AC. If itis difficult to them they could just buy it!![]()
Below is a snapshot from the rxDuplicator 1.12 Add-on for AC9 from the late arexline.com. If it was still operational I would have been their firs client!
ā2007-07-15 05:14 PM
