2006-06-01 03:21 AM
2006-06-01 03:33 AM
2006-06-01 04:36 AM
2006-06-01 06:06 AM
2006-06-01 07:49 AM
NOELDESIGNS wrote:Grant,
Rick, thanks for your reply, but perhaps you misunderstood my posting, or perhaps I did not explain it correctly.
I am not criticizing AC 10 in any way as I have not used it extensively.
My concern is that after installing AC 10, the installation messed up AC 9, and that to me is unacceptable.
Here is what happened.
I installed AC 10 per the instructions. I played around with it just to see what the new version is like. I did not open any AC 9 PLN or LBK files in AC 10 since I am not that familiar with the new version.
I closed AC 10, and opened Plotmaker to continue working using the AC 9 and Plotmaker combination.
I selected Publisher so that I could publish some work using PDF files.
Usually I have the option to choose the format, and I use PDF.
However, now PDF is not an allowable option, which it had been ever since AC 9 came out.
For some reason, once AC 10 is installed, it wipes out the PDF option under publisher in Plotmaker(the one that came with AC 9).
AC 10 and AC 9 should be totally separate applications, with one not having any affect on the other. This is not the case.
Grant
2006-06-01 10:15 AM
2006-06-01 02:01 PM
2006-06-01 05:57 PM
2006-06-02 10:13 AM
NOELDESIGNS wrote:It is that simple. If you don't see the PDF in the printing or publishing options, that means that there is no PDF printer installed. Close Archicad, reinstall. Done. Remember this as a general rule.
But, what is more frustrating with this issue is that the local tech support person nor the distributor came up with a solution to this problem, which is bothersome particularly when the solution is so simple as Link and Eric have stated.
2006-06-02 01:53 PM
