Don't appear the icon tools (tooltips)
I have the v.15 installed and by reaching an icon with the pointer I cannot see the information of it, but a really small one. Does anybody can help??
Thanks
4 REPLIES 4
Link
That just looks like the slider to me, not the tool tip.
Go to Help> Show Tool Tips.
Link.
This problem with tooltips showing up as small lozenges instead of the full tooltip happened before ... and I cannot remember the solution! But, at least I can tell you that you're not crazy. 😉
One of the forum moderators
Aha. Here is the thread describing this issue and the solution (workaround):
http://archicad-talk.graphisoft.com/viewtopic.php?t=25254
Actually it is the tool tip and the solution was the size of text on the screen set to 125%. I had to set it to 100%.
Thank you!!
